What kind of control does it use? You MUST be able to put the Z zero anywhere you want...you just need to figure out how. Geneally you just move the machine til the cutter touches the top of the stock, then zero the axis. Don't break your bosses machine. call the machine support people if you need to. Also Meshcam can change the top of stock to something other than zero. I think it's under CAM, Defiine stock. Set the Z for .5" (or whatever works for you)
Eric
Eric
__________________ I wish it wouldn't crash. |
