Old 04-26-2003, 07:06 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Partition magic
Paul,
No problem. I have one machine with Win98se, XP, and Dos on it.
The Dos partition must go one the first disk(if you have more than one) and below 1024 cylinders as the book states then Win95/98, then XP.
It is also handy to create a "swap partition" and format it Fat 16.
That way you can use it for both Dos and XP. Say to transfer program files from XP (cad/cam) to Dos for the control.
If you do create a swap partition it would need to be right after Dos on the first part of the drive.
I use Partition magic ver 7.
Only draw back is you can't run a Raid 0 setup.(mirror) with partition magic ver 7. If that matters. Maybe in ver 8 you can I don't know.
Good luck, It's pretty easy to use.
