Old 10-13-2006, 05:17 PM
BMackinnon BMackinnon is offline
BMackinnon is on a distinguished road
Originally Posted by NC Cams View Post
Am I wrong in assuming that the optimum RPM when you start to feed in the tool to cut will ultimately depned on:
A. the diameter of the part being cut
and
B. the optimum surface footage that the material wants to be cut at??
When/if you run out of rpm potential for the spindle, at that point the surface finish will start to suffer.
not necesarly true when threading ... it is faster to run threads at high speeds with a good amount for a depth of cut or number of cuts compared to what the stanards/formuals call out. The SFM dosent matter as much as it would if you were turing/boring the OD/ID since you are not worrying about chip break or burning the tool/material cause you are not taking off that much at a time. You'll break/chip the insert before you burn it up if your depths are not right.
