Old 10-13-2006, 05:03 PM
jhowelb jhowelb is offline
jhowelb is an unknown quantity at this point
All solder joints are "text book" perfect, cleaned and trimed. All plugs and power and ground connections are a-ok. Unit shut down and turned back on repeatedly (even overnight) and still the voltage at the "test pads" is almost non-existant while the power input block shows 40 vdc. The fan block shows 24 volts, the 5 volt pad shows .6 volts! GGGRRRRR!!!
Ready to throw baby and bath water out!
