Old 10-13-2006, 03:37 PM
NC Cams NC Cams is offline
NC Cams is on a distinguished road
Am I wrong in assuming that the optimum RPM when you start to feed in the tool to cut will ultimately depned on:
A. the diameter of the part being cut
and
B. the optimum surface footage that the material wants to be cut at??
When/if you run out of rpm potential for the spindle, at that point the surface finish will start to suffer.
