Old 01-25-2004, 08:04 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
I don't have my camsoft manual in front of me, but does the multifunction knob command have the same limitations? Perhaps you could load some presets into that, and control it with a couple of I/O points? I'm thinking of simple momentary contacts to increment the knob position up or down.
I'm assuming that you really only need a start and a run setting, and that you could preload the values into the multifunction knob? This might be a bit of a pain if you have to change these values a lot.
