MACH 2 configuration for Xylotex Board | | I have downloaded the MACH 2 S/W I am now trying to have it work with my xylotex (XS-3525/8S-3) Stepper Motor Driver Board.
According to xylotex all I need to tell the software is the information below. I did read you PDF help document but as a beginner all of this is very new to me.
The 26 pin header is configured to allow easy connection via
ribbon cable to an IDC DB-25 connector. This facilitates direct
connection to standard PC parallel ports.
The drive uses the following signals:
DB25 pin IDC26 Usage
Pin 2 3 Step X
Pin 3 5 Dir X
Pin 4 7 Step Y
Pin 5 9 Dir Y
Pin 6 11 Step Z
Pin 7 13 Dir Z
The remaining signals are fed to other headers to allow offboard
devices to use the other parallel port signals.
Also provided are HOME(HPO#) outputs, ENABLE(ENA#),
and SLEEP# inputs for each axis.
If anyone can provide further instructions or a Mach 2 profile I could use it would be greatly appreciated.
Norman |
