You don't say if the machine is new to you or if you are familiar with it. I assume it's got a Fanuc control. Usually you will get this message until you have referenced the machine using ZRN switch and + / - keys to send each axis to it's reference position. Holding down P Q and cancel whilst turning on the Power will reset the axis controls which sometimes helps in a situation like this. Good luck, Nick. |
