Old 10-11-2006, 08:33 AM
dannystooblue dannystooblue is offline
dannystooblue is on a distinguished road
need advise on HID's
I am reaching the point of my benchmill conversion where I am jogging the machine around and getting ready to do some cutting. I have a few questions that are eating away in my mind. Let’s start with letting you know I am a machinist, not an electronics technician or a VB guru. I am somewhat computer literate though.
1) What is the best way to implement an encoder as an mpg
a) I can use a modIO and the serial port ( will this translate the pulses)
b) I can use a keyboard immulator and key grabber ( leaning this way )
1) would this use mpg in mach or would it be set to step?
c) I can interface with the parallel port ( is this a modIO? Will it translate the pulses?)
d) What would be the easiest way to have an encoder as an mpg for each axis?
e) Use the “shuttle” devise that has been talked about a little lately instead?
f) Any other options that I have missed while reading through posts?
2) What is the best way to implement my e-stop, would I use a relay? My power supply matches my needs pretty close at 48vdc, I expect somewhere around 15 to 20 amps max.
3) Are there any plans floating around for a tool changer for the rongfu square column mill?
4) If I choose a modIO and wire my encoders in to it will I be able to power off the drives and manually move the machine around with handles and then power them back up without loosing position (like a standard eztrak)
5) What is the best way to implement a feed override knob?
Thanks, Danny
