Gas? | | What, if any, gasses are you using to cut with ??? I use o2 with the ht2000. I cut everything from 14 ga to 5/8 with 200 amp nozzle and electrode ect. I adjust cut speed, stand off, gas pressure, and feed to achieve nice cuts on all. I also punch all holes since the machine is equiped with a 40 ton ram. I just recently started using a laser to cut 8mm and under with excellent results, laser is the way to go ! |
