Recommendations for Vinyl cutting software | | I currently have LXI software. I'm looking for other software that might give a little more info.
Although most of what I do is designed or laid out in Adobe IL 10 and then imported- I would be very interested in the opinions of others as to what plotter cutter software seems to be the easiest to decipher without spending a fortune? It easily imports EPS ver 8, but isn't clear about what cuts and what doesn't. to be more specific - I thought it would cut everything in the preview pane of the production manager, but chopped the top of of one line. How do I get it to NOT do that.
I have a 24" Panther cutter. No tech support with it. I'm trying to learn the basics by reading the manuals of both the cutter and the software and find the most basic questions - skipped. standard types of material recommended - maximum and minimum widths of vinyl it will cut (ie - if it fits under the roller somewhere - 3" under one roller?)
I'm always looking for suggestions and advice from those of you who have experience with these machines.
Thanks,
Susie |
