These questions are real hard to answer not knowing the Tree model, and the condition of the present electronics.You may be able to use your present servos, you may be able to use the encoders, you may be able to use some of the relays, but If the controls are toast, then you will need a controller ( breakout board) servo amps,) a PC and software matched to the controller,wiring and the ability to read/interpert electrical diagrams , test and diagnostic ability.The other questions is how is your spindle controlled ? Programable VFD ? DC servo type motor ?
I would say that if you need new ball screws and bearings, then if you got the machine as a "gift"( I.E. free) sell what you can on E bay as parts and look for a better machine.Ball screws, ABEC 7 matched bearings etc = $2800.00 plus,
Needing new ball screws means the machine was abused, or overused or the oiling system is inoperative or plugged. That would mean the ways, gibbs and other sliding surfaces are most likly in need of re-scraping or are just junk.The spindle is another issue that can get real pricey .I do not say that you would not have the skill and knowledge to repair, regrind a spindle, but that is a Science and Art, just second to brain surgery. Check the posts by Walt @ SGS,and I know HuFlungDung also rebuilt one of his machines spindles, but he is a highly skilled machinest/mechanic. Walt does it as a living,and have heard nothing but good about his skill and product.
For a retro-fit your cost can be anywhere between $3000.00 to $12,000.00
depending on how you want to configure, bells and whistles, software etc..and believe me there is a learning curve that takes time and concentration.
Best advice is be carefull of your purchase, read all the threads on mill retrofits you can, then look at some of the new offerings for three axis mills, there are a lot of nice CNC mills ,new, done with good controls for $12,000 to $21000.00, have a warrenty and service.
Adobe (old as dirt) |
