Old 10-09-2006, 04:26 PM
sdantonio's Avatar
sdantonio sdantonio is offline
sdantonio is on a distinguished road
setting 0,0,0 in Mach3 Mill
I've attached a jpeg to make this easier (I was going to try to just describe the question without pictures.
Given a block attached to to router table top and a project that is approximately symmetrical with respect to the y axis, the position 0,0,0 (home) is typically set at point "1" on the diagram (at least that is my understanding). Is there a problem, or will Mack3 have a stroke, if I want to set 0,0,0 at point 2 on the line of symmetry?
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
