Can i get more? | | Thank you for the information.
But from where do you measure tlo?from the collet to the tip?(A section)
or the cutting portion?(B section).Because if your endmill has body diameter 6mm and the cutting portion has 3 mm diameter,i believe you have to take into account the B section.I know that TLO helps in tool changing but,if you can explain what do you measure to find TLO i will be glad!!!Do you need the probe for that job? |
