  #10
Old 10-07-2006, 11:24 AM
diarmaid's Avatar
diarmaid diarmaid is offline
*Registered*
diarmaid is on a distinguished road
Question 1:
There are different sets included with the Driver Kit, which each consist of three (3) items. I do not know which is which?
The only sets of 3 items on the contents list are the capacitors above, the resistors above, the driver chips and the following two items. Hopefully someone can clarify this. These two sets of items are:
Three (3) 2x4 Pin Header
Three (3) 1K 1/2 W Potentiometer
The three sets of items I cannot identify are shown in the pics below.
Thankyou.
The fourth pic I think is the .1uF capacitors. Can someone please clarify this?
If these are the capacitors my only problem with the kit so far which is a very minor one is that one (1) of these was missing. This is understandable when packing such a large number of different small components.
EDIT:
Ok, when I started putting it all together I realised that each of these only fits into its own hole, and each hole is numbered on the PCB so its fairly easy to figure out:
The first three (3) little blue things are the 1K 1/2 W Potentiometer's.
The second three (3) are the (Which Dave was kind enough to e-mail me to also point out):
1 x LM317 Adjustable Voltage Regulator
1 x 7824CV 24V Voltage Regulator
1 x LM317HV Adjustable Voltage Regulator
The different name of each one is printed onto it, so they cant be mixed up.
The third three (3) are the 2x3 Pin Header's. I discuss problems with these in a later post.
ID:	23833   Click image for larger version
ID:	23834   Click image for larger version
ID:	23835   Click image for larger version
