looking at the second method there but cycle time is an issue so this would have a bad affect on it.
I am going to try and change the infeed angle on the first G76 line it is set to 29deg so the back of the thread would be rubbing all the time.
If i change this to 32 then the front would be cutting and not the back just not sure on the Puma on the fanucs we have this is okay as the last two finishing passes are plunged so it brings back to the correct angle, again not sure if the pumas do this. |
