  #12
Old 10-04-2006, 07:35 PM
CJL5585 CJL5585 is offline
Gold Member
CJL5585 is on a distinguished road
Originally Posted by bigz1 View Post
Jerry being clueless about electrics this is a great help. Thanks.
If I were to put another homing switch in parrallel on the X axis could I have 2 'origins' on my machine, with the option to ignore 1 if I want to use the full cutting area?
As Smarbaga suggests in the next post, many home switches are mounted on a slider or mechanism where they are moveable if desired. In commercial applications the home switches are sometimes adjusted to a new position with each job as the machine setup changes.
You can wire two homing switches in parallel if you so desire, but the machine will home on the first switch it sees. However, if you have a means to switch the closest switch out of the circuit, the machine will home on the second switch.
