Actually after three months I would recommend program to brake the spindle in for new machines.The run time is aprox. 2 hours.If you call Haas seervice they may help you.
Here is the 2020 program
O02020 (Spindle Warm-up)
(This program should be run prior to)
(machine use if machine has been idle)
(for more than 4 days.)
(Cycle time: 20-minutes.)
(This program can be used for all)
(spindle types and may be used daily)
(for spindle warm-up prior to high)
(speed spindle use. Adjust spindle)
(speed override depending on maximum)
(spindle speed of machine: Set)
(override at 50% for 5,000 rpm)
(machines, set at 100% for 7,500)
(& 10,000 rpm machines, and set at)
(150% for 15,000 rpm machines.)
(9-21-99)
S500 M03
G04 P200.
S1000 M03
G04 P200.
S2500 M03
G04 P200.
S5000 M03
G04 P200.
S7500 M03
G04 P200.
S10000 M03
G04 P200.
M30
