Originally Posted by txcowdog I use older style ShopVac hose that collapses easily. It is basically a large spring covered in plastic. I can only find it at a vacuum cleaner supply because Home Depot only carries the newer style of hose that is hard plastic that bends easily but does not collapse. Attach the hose at both ends over the screw and it expands and contracts easily keeping the screw spotless. |
That seems like a pretty good ideal. Do you have any pics of the setup. Something I could print out and take around to see if any of the shops around here sell them.
