V22 | |
Originally Posted by cbucner They should have a twist funtion,for this kind of software that's a need!!!
Maybe somebody will hear us and do it in the new ver 22.
They should also have the real time drag and drop of objects not the way it's now .
I did alot of corel before and I'm used to power of corel.
And there way many more things that a software like bobcad should have.
Personally I find very hard to select the direction of the chains .
It takes me 3-4 times at least to get the chains selected for creating surfaces, most of the times the direction changes on you right before you cick and that's it, it's screwed, or it changes when you click and I really hate that.
Anyway I'm trying to understand most of it .
Toby, I have a question.
If you have for example a cube that you make it out of 6 planar surfaces not using the cube function, or any other geometry made by joining more surfaces , it's not considered a solid?? is it??
Because let's say i do a cube out of 6 planar face surfaces, then I want to use a cilinder right trough my cube and use the boolean function difference
it doesn't do what it does if you are using a reg cube function.
My question is how can you make a geometry made out of many surfaces a solid.
Any advice will be much appreciated.
Where are you located toby??
I'm in IL , Do you have an email where I can email you an access to my server so you can upload the cad file you did??
Thanks |
V22 will be a lot different than previous Versions of BCC because it is a total re-write from scratch
We will all need to be here and other places when it is released
__________________ Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com |
