  #11   Ban this user!
Old 09-22-2006, 11:06 PM
moreil moreil is offline
moreil is on a distinguished road
Spent the morning doing foam cutting using FCut, so there's a fair bit of polish added.
1. Finally fix the bug preventing negative values in manual move mode.
2. Fixed bug where the foam depth offset wasn't being used.
3. Fixed bug where the foam was drawn in the wrong position in the top view window.
4. Fixed bug where the foam width offset wasn't always being recalculated when the foam position changed.
5. Fix major bug where heat wasn't being set when the wire moved.
6. Fix bug where move window wasn't being automatically closed when move finished.
7. Fix bug where heat wasn't being set on manual moves, unfortunately requires a driver update.
8. Feature: Turn off heat at end of cut, sync'ed with wire motion.
9. Bug: Projecting the shape to the wire supports now works correctly, and copes with different span shapes being cut in the same core.
10. Feature: The shape is now automatically centered in the foam shape.
11. Bug: Right/Left wing box didn't instantly update drawing on changed value.
12. Bug: Wing occasionally lost track of setting slope by dihedral angle or basic height. Now remembers which one was set last.
13. Bug: Kerf values were the wrong way around
14. Bug: Kerf were at max speed and min speed, instead of max speed and max speed/2.
15. Bug: The warning message about a missing interrupt generator was occasionally falsely triggered.
16. Bug: The kerf values where treated as a radius instead of as a diameter.
17. Feature: Warn if the kernel driver is out of date.
See http://fcut.sf.net as normal
