The wheel has never worked in properly in mine, from V.5 up to V10.75! Nor on any of my collegues PCs... it does work if you wheel slowly, but try and skim through a program and it goes a bit mental and flips all over the place.
CTRL-A doesn't work. (select all)
CTRL-H doesn't work. (find and replace)
Others too.
Also no backplotter, which is a huge drawback, and a complete lack of useful commands like 'delete blank lines', you can't bookmark lines, and lots of things I'd expect to find in a NC editor.
Nothing wrong with it per se, I just find it a bit basic.
Nice idea Bent, just tried it and that did the trick. Ta! |
