Hi Wakeboard,
Yes there are machines available. If you want to bend sheet metal, the machine is called a brake.
For heavier sections, a hydraulic press would commonly be used. This requires a male/female die combination to create an accurate shape. Lots of guys build their own hydraulic press frames, using an inexpensive hydraulic jack to create the needed force.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
