Phil,
There isn't a way to do this the way you described, but I'll add this to the list. In the meantime, I think this will work:
On the viewport click the first line that you want to delete. The corresponding G-Code line is selected in the program. Right-click the program window and click "Select From".
Then, on the viewport click the last line that you want to delete. The corresponding G-Code line is selected in the program. Right-click the program window and click "Select To".
This should select the entire range of the program from the first line to the second line. Then just press "Delete" to erase it.
Hope this helps,
Scott |
