  #11   Ban this user!
Old 09-15-2006, 04:35 PM
Torchhead Torchhead is offline
Torchhead is on a distinguished road
Or....(for something completely different) use the method the sandcarvers use for glass etching: Cut the stencil/mask in sandblast resist uisng a vinyl cutter. Paint/anodize your base coat first. Mask everything you want protected and weed out the cut design on the sandblast mask. For light sandblasting you can get by with Paint resist grade vinyl. Sandblast the design into the base color/metal as deep as you want. With the mask still in place spray the color you want on the design. Peal and marvel!
While they do this on glass and leave the base as clear and the fill as a metallic, the same approach works.
