George
I did ther physical movement of the drive belt in the x axis.
then I did the start up, it moved the quill down and up, and then I did the home process and that worked.
BUT then after that, when I would try to jog, I would get the ERROR light.
the display indicated " Enabel drive axis"
I would key enter: then display read "Jog x axis limit"
if attempting to jog in Y i jgot the same message.
same for X.
This machine worked the last time I put it under power, and it passed all the self test. and all worked, I did not have air line pressure so I the spindle would not run. We were only testing out operations.
Then a worker ran the table the the extreme left. And that is when all this probelm started.
What can I do now?
thanks
Richard |
