Originally Posted by truman OK I have stiffened the gantry up with 1" square tubing but I have found out that it is the bottom plate that is the weakest link. If I hold both gantry sides and move them in opposite directions I get what I think is called gantry rack. Anyone have ideas how to improve this? any help would be greatly appreciated.
thank you
Rob | Again...
Originally Posted by HayTay You could use aluminum or steel angle to stiffen up all of the corners on the gantry. The outside corners for sure, and maybe the inside ones, too.
It looks like you should remake the sides of your gantry to make them longer on the underside of your table frame. You could then add front and back plates made from wood or metal to stiffen the assembly up even more. A torsion box assembly would probably make it even stiffer than just the front and back support pieces.
See Joe's CNC Model 2006 gantry for inspiration: http://www.cnczone.com/forums/showpo...0&postcount=42
If you're going to remake the gantry, now's the time. I hope the suggestions give you the help you were looking for. |
__________________ HayTay
Don't be the one that stands in the way of your success! |
