hanging the weight from the bottom of your z slide will make it worse, hang the weight behind the column using cables and pullys up and over. mounts for cables will have to be to hollow portion of box not entering oil chamber, and as far to front as possible, and definately get the z saddle modification done by aaron. better concider at least a little bit of lapping too to insure a smooth slide.
__________________ Don
IH v-3 early model owner |
