Hooking up the xylotex board | | Wow, this is not nearly as simple as everyone says it is, you must all be freakin geniuses. (genii??)
I have e-mailed Xylotex for help, but I am hoping someone can point me in the right direction.
I am running Mach2, on my 3 axis router. I have limit switches in series on one end of X and Y, and home switches wired individually on the other end of X and Y and on Z.
I cant find anywhere where it says where on the board these get hooked up to. I have read everything I can find, and nowhere does it say where these can go.
From what I understand, the board just routes these into the parallel connector, and then you configure in Mach2 what each signal means.
Help me if you can,
co |
