Old 09-10-2006, 07:46 PM
NC Cams NC Cams is offline
NC Cams is on a distinguished road
You can determine the "sufficiency" of the bearing to absorb thrust by measuring its dimensions (or pulling the part number from it if one can be found) and checking the Torrington catalog for the static thrust capacity of the item once you identify it.
If you don't know the potential thrust that will be applied by your machine via the screw, your guess is as good as anyone's as to the ability of the bearing to absorb thrust.
