The material would be aluminum with clear anodized finishing. They have big series in production. If someone orders 6 different pulleys (1 un. each) you have to pay for the job preparation. The lead time would be 4 to 6 weeks. At the phone they said it would be expensive but there is expensive and EXPENSIVE! I assume they deliver top quality work.
On the Aire Bearings order regarding the big pulleys we are talking about:
One 367mm Diam, 144 teeth, HTD 8M, 30mm width with taper bore
Two 216mm Diam, 136 teeth, HTD 5M, 15mm width with taper bore
3 smaller ones
6 taper bushes
3 Gates HTD belts
1 shaft Drivelock 70 bush
Lead time 1 to 2 days. Everything in stock... |
