Hi John
I didnt wanna name names in a negative light, but no I have not tried flashcut or deskcnc as they both have to require propriotary
hardware to operate. all the ones I used where software ment to output through parallel port with any special hardware or pulse generator.
Jeff
Really was not trying to compare to mach 1 or 2 as I have not tried either because I dont have a PC in my shop capable of running win 2000 or XP. I have tested master 5 but my main reason for being so pleased with cncpro was the significate speed increase which when using master5 there was no noteable increase although if I could afford another faster PC
and Mach2 software Im sure what you say is true
Regards
__________________ Learn from the mistakes of others you can't afford to make them all yourself! |
