Old 09-07-2006, 07:24 PM
Geof Geof is offline
Originally Posted by raytor View Post
Could someone explain the setup for milling a dome shape using a manual (non CNC) 3 axis mill?
A variety for accessory tooling is on hand as well but no lathe.
Do you have a rotary table?
Can the head of your machine be set at an angle?
If the answer is yes to both I can make a sketch of a setup that will machine a spherical surface.
