Thanks for your reply.
This is the 1st time i try to programfor a Pulse Laser machine equiped with X,Y,Z,A,C,D.
C is attached and rotate perpendictcularity with the head,D is attached to C and rotate up,down.
The task require to drill some compound angle holes.I programmed and posted for 5axis bridge mill (spost).
Codes for machine came out different in angle (A,B),and even location is way off.
With mpost I could see what happened,but it is just up to 4 axis.
Attached is the files with some points.
Thanks |
