Old 01-13-2004, 06:36 PM
cbcnc cbcnc is offline
cbcnc is on a distinguished road
Thanks Jeff,
I'll just put a piece on the tablesaw and try it. I have cut alot of aluminum on it without a problem. I find that with alum you get a better cut if you use a lube stick to prevent buildup on the blade. I'm using a standard 60 tooth carbide finishing blade. Someday, maybe soon, I will spend the $60 for a metal cutting blade.
As far as my bandsaw goes I can slow it down to 700 rpm or 5400 fpm. Do you think that is too fast?
My router is a Porter Cable trim router and goes at 30,000 rpm. I do have a speed control for it. I also have 1/4" and 1/8", 2 and 4 flute milling cutters.
Part of my problem is I don't have that much material to make scrap out of. But, here goes.
Chris
