Old 09-05-2006, 10:07 AM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by bd007 View Post
I have been using my JGRO for cutting 1/2" mdf but I am getting tool marks mainly going around curves, straight cuts are not that bad. Does anyone have any tips/tricks for getting smoother cuts around curves? Should I try increasing the router rpm, I'm afraid I may start burning the wood?
I am using turbocnc with an Onsrud 1/8" upcut spiral with .125" depth per cut. My router is a 1-1/2 hp peak craftsman with a HF speed control.
This is called (Chatter) What is your feedrate and microstepping, Alot of times its the machine not being tight enough, meaning movement at the cutting bit..... I got this more from my cheaper built DIY machines until I built my double rail system, which made everything alot more tighter, Also your piperails may cause the chatter if they are not smooth enough.
