Old 09-05-2006, 10:03 AM
chipproducer's Avatar
chipproducer chipproducer is offline
chipproducer is on a distinguished road
are you using coolant?
I find that it often helps even in plastics. Just make sure to clean them good after, as they tend to absorb water and swell over time.
Two flutes are a must. If you don't use coolant, blow air on the cutter to move the chips out of the way.
