We all do this on a daily basis in the plasma world. We use a "floating head" that when moved towards Z home trips a switch and the switch offset programmed into Mach so you can find the top of material. Wouldn't work with a router (flaoting head) but I have seen a simple touch plate (piece of aluminum that acts as a switch when the bit contacts it) hooked to do the same thing. |
