Old 09-03-2006, 02:59 PM
bpmufx bpmufx is offline
bpmufx is on a distinguished road
Hey Mike,
Thanks for the heads up. BTW Are you coming at this from any past CAM background to compare with?
Also, did you compare with MeshCAM? Any thoughts to share if you did?
Rhino definately can import OBJ files but as I'm sure you aware, its a mesh model, and there's not much that can be done with meshes. So I'm really curious whether it would need be turned into a surface model first.
I have MasterCAM, SurfCAM, & BobCAM experience, and I'm curious how MadCAM holds up. I can certainly allow for a lot considering the $$.
Evan Brainard
Windmere Design
Autodesk Inventor Consultant
windmeredes@comcast.net
