  #12
Old 09-03-2006, 03:07 AM
dertsap's Avatar
dertsap dertsap is offline
Gold Member
dertsap is on a distinguished road
Originally Posted by pulsar200 View Post
until I get acceptable results. Is it possible to set the default maximum acceleration in my milling program? or is it included in the g-code?
Best regards
- Martin H. Pedersen
you set the max in the control software be it mach or what have you , for example , if the control is set to travel the motors at 100ipm ,and your program has a feed of 150ipm the max the motors will run at is 100 ipm
set the accelerate low and try the motor then bump up the accel until it looses steps , ,then back off the accel some ,that will be the max
