Originally Posted by TURN ME using cnc lathe machining mainly Aluminum, Mild Steel, Hard Steel, and delrin
would like it to be a universal tool for all the above.
or at least for mild to hard steel. - |
In this case use an Indexable Insert Drill and clean the bottom with a Special Ground Boring Bar. Also if the hole is extremely deep I suggest truing the outside and sending out for Gun Drilling. Gun Drilling can be done within .001 depth, diameter, and perpendicularity to the true face and outside diameter. Then you will have to make an Arbor to finish the rest of the work in the Lathe.
Bouble Post..........................Weird..............................
