Old 01-12-2004, 10:32 AM
NeoMoses's Avatar
NeoMoses NeoMoses is offline
NeoMoses is on a distinguished road
Originally posted by buscht
Bryan, thanks for posting the information. Very informative.
Would it be possible to hook up a stepper motor to make some kind of automated dipping system? Or do you need an operator to make judgement calls as to the depth of color?
T
Yes and Yes. It is possible to hook up a stepper or servo driven linear slide to do this once you know how long you want the darkest part to be in the dye. For example, let's say I want to fade from blue to silver, and it takes 10 minutes to fully absorb blue dye. Also, let's say that my part is 10 inches long. So... we should dip the part, with the darkest end being submerged first, traversing 10 inches in 10 minutes, or 1 IPM - an ideal situation for CNC.
However, let's say you want a slate blue, and you don't know how long it takes to absorb the dye to achieve that color. NC wouldn't work very well here. Or, take the case where the part is an odd geometry and you can't get it to hang correctly for the fade you want, but you can hold it by hand.
Basically, both CNC and hand-operated methods will work, and each has it pros and cons. Choose whichever works best for you.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
