Old 09-01-2006, 03:02 PM
QSIMDO QSIMDO is offline
QSIMDO is on a distinguished road
Squaring; wonder how this would work?
I believe there's a picture around here of the bottom of a Tormach column which apparently shows adjusting screws instead of using shims for squaring.
Is that correct?
So how would it be if I drilled and tapped the IH column for such adjusters?
My greatest concern would be torquing down the column bolts and snapping a corner off the column base. Perhaps though if the adjuster screws were close enough to the column bolts the force would be directed straight down through them and not so much at an angle if the adjusters were some distance away.
Thoughts?
