I think that 18mm would be ok - you could always add a stiffening rib or two if you had too much flex. Or you could use 12mm and add a few stiffeners - might be lighter AND stiffer than the 18mm.
Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
