Old 08-30-2006, 03:25 PM
Deviant Deviant is offline
Deviant is on a distinguished road
I have no plans to drill into the actually machine plate. This would have negative effects on it's retail value.
The plan was to make a plate that is the full length/width of the existing table. And never remove that place. Additional fixtures would be made to mount onto that plate in a manner that allows you to switch out for each machine process.
I will be doing alot of one-off type stuff. But I have a few items that I will make several off. This is what I'm looking to speed up. I'm also looking at the possibility of utilizing homing switchs so I can dummy proof the parts.
I don't doubt that I can make a smaller table, but I'm a little confused how to make a table that is the full width/length of the machines table. I'm not sure how to go about the clamping to the table. Since I will need to flycut both sides before I drill/tap any holes.
I figured it would be easier for someone with a larger mill to make something like this.
