Old 08-30-2006, 05:17 AM
philbur philbur is offline
philbur is on a distinguished road
Yes but not so sweet if you also want to use it with the axis vertically.
I don't think software is an issue for the table design. The 4th axis only sees pulses from MACH2 or whatever control software you use. If your software produces gcode for a forth axis then you're in buisiness if it doesn't then you are writing/editing by hand or transposing axis (not sure if that's the correct terminology) in MACH.
Regards
Phil
Originally Posted by lilricky2
Sweet! I never thought about that approach. What kind of software are you running?
