Anybody here using Cimcool and can make it work? | | A little background first...
I work at a fairly small shop, we have two departments. Lathe and Mill. Two owners, each owns his own section. With the mills (where I work), we used this stuff called Trim E190. It worked well, but smelled awful and the rust inhibitors were sub-par.
In the lathe dept, Cimcool was used for all 3 CNC lathes.
Due to the rust problems, we switched the coolant in one of the mills to Cimcool. My experience with it has been awful. Yet the owner of the lathe dept says it is the greatest coolant.
Here is the situation:
3960RPM
.312" ISCAR ball insert cutter, 2 flute.
410 Stainless steel
Feeding at 50IPM @ .036"
The finish is awful. We have run thousands of these parts with excellent results, never has the finish been so lousy. According to the Vee Gee Refractometer, coolant concentration is 6.5%.
Does anybody have any suggestions of how to make better use of this CImcool product? |
