we do core and cavity cut files from center of mold, and then after we finish cut, we put in the toolingballs.
It all depends, The less manual input, the less chance of a mistake. If your doing plats via manual xyz input, then it would be wise to go from center (because most of the time it's cymetrical) However if you get solid files, it would probably be better to stay at the work corner so you can eliminate somebody punching in the wrong number when moving, and to eliminate setting up the plate wrong way..... |
