Put a dial indicator in the chuck and bring it down to one side of the table, set to zero, then move to the other side of the table. This will tell you if it is the machine. If its not the machine (the dial indicator does not move ) then set the acrylic tags up, then run the dial indicator over it from one side to the other. It could be the thickness of the acrylic tags. |
