If I pump it a few times manually in a short time I can visually inspect and see the way lube. It is evident on the quill, Y axis, you have to get pretty crafty with a mirror and a flashlight but it definantly does lube the x and the screws.
I don't think it runs in that case- I have never once seen the plunger lift on its own. I guess I"ll have to take a peek and see if its hooked up to power correctly and such inside the case. I do know the low lube alarm is just jumpered. |
